Het is nu 15 mei 2024 10:26
 Berichttitel: 20 perc diezel besparen ?
BerichtGeplaatst: 09 apr 2006 09:16
voor wie goed Engels verstaat :-k
Diesel & Petrol Fuel Saver
Cut your rising fuel costs & reduce your harmful emissions. The Magno-Flo Fuel Saving Unit is an incredibly powerful fuel conditioner that attaches to your vehicle's fuel line and will save you up to 20% on fuel costs. Our units will reduce your fuel consumption whilst also reducing harmful emissions. Magno-Flo can also improve the performance of your diesel engine. Magno-Flo has been researching and developing this product for 15 years. Our product has been fully tested and published under strict test conditions by the Bolton Institute.
Magno-Flo has been designed so they are very easily fitted and require no skills to fit. Our design will allow our product to be fitted to any size of pipe up to 22mm in diameter.
Fuel prices are not going to go down but you can reduce the amount you need to use with Magno-Flo, saving you money and doing your bit to fight pollution and help the environment.
Diesel Vehicles (Individual Injectors)
If you have a vehicle with individual injector pipes larger than 3mm in diameter, this system will give an increase in power output with economy with the advantage of making the engine run quieter.
Deze thread heeft 17 replies
Gebruikers op dit forum: Franco
